Issue with the led indicator on my S3
Ioioana
5
Hey, I've just noticed that the led indicator's light on my s3 is dimmer than usual when I plugged the charger in. Then it went back to normal for like a few seconds but now it's still dim. Does any of you know what might cause this? Thank you! :)
I believe I've had this happen the one time that I used light flow in conjunction with the stock led battery light
By any chance are u using that app?
I used to use physical buttons, and then I found button savior
-S. T. C
Sent from my rooted, debloated CM10 jelly bean 4.1.2 Samsung Galaxy S3 #LikeABo$$
No I am not using this app. This happened though right after I updated my system to 4.1.1 Android. I'm thinking that maybe it has to do with this :-??
Yea, probably something to do with the rom you flashed I guess
-S. T. C
Yeah I'll just leave it alone for the moment. Anyway thanks for the reply. :)
Maybe try re flashing and see, or waiting
I had a problem with my rom a fee days ago, the notifications were automatically expanded when I pulled down my status bar, but it's magically fixed itself now
-S. T. C
Im having this problem after i updated the system too. It is just dimmer than usual. Anyway to fix this?
stopwatch
