Issue with wireless charging when screen turns off
Ash Powell
3
I picked up my S6 yesterday and also got the Samsung wireless charging plate with it.
The problem I'm facing is that when ever the phone screen turns off (whether it's me turning it off or the screen timing out) the wireless charging pauses, stops and then starts again giving this little beep sound. I thought nothing of it and left it 'charging' overnight and in the morning it had charged from 8% to 3%...
Is there something I'm not doing right? Should it wirelessly charge while the screen is off?
Is the phone sitting in the middle of the wireless charger? If it is not sitting on the charger properly, it will not charge. Sometimes keeping the phone on vibrate will cause the phone to move slightly while it's charging and pause the wireless charging. Keep sound on or turn it off. I know it sounds crazy but this is S6 life lol. I would remove the case (if you have one on) and try it again. There is a blue light that is illuminated on the samsung wireless charger when it is charging your phone properly. Make sure you see it so you'll know. As well as the LED light in the front of the phone that alerts you that your phone is charging. Make sure you purchased your wireless charger from an authorized dealer as you know people are counterfeiting everything now a days and may advertise that they are selling the real thing. Good luck and keep us posted
Galaxy S6 Gang
So the phone is charging without problem, until the screen turns off, as long as the screen is on it will charge fine.
No case, and the Samsung wireless charge came from O2
alright, did some looking around and found this. Try it and let me know how it goes. Set Daydream (under Settings, then Display and Wallpaper) to happen when charging (it is set to Off by default), so it no longer will go into screen lock when you engage the charger, it will lock when you remove it from the charger. Could be an app installed in your phone that is causing the malfunction as well. Another option is to restart your phone in safe mode and see if it charges fine. Then you'll know if it's an app. Just gotta figure out which one. Live wallpapers is a known culprit. Good luck!!
I'm still struggling with this. Using silly daydream mode to prevent my wireless charging from tripping out. Is there not yet a fix for this?? This is ridiculous. I hate daydream mode. Can't my phone wirelessly charge with the screen off like a normal device?
So glad to find this post. Just tested this and sure enough, it is the display going to sleep when it stops charging...
Oddly enough, I have two identical wireless chargers, one at work plugged in using a USB port on my PC and one at home plugged in using the Samsung AC adapter that came with my phone, and it is only the one at work that is experiencing the problem. I wonder if the USB supplies less power and so can't maintain the charge connection as easily. But why would the display going to sleep make a difference in that case?
If you're using USB 2.0 in there anywhere (the PC port, the cable, the wireless charging pad), you're only getting 480mA charging current at the most. (And if the phone is discharging when it's on the charger, it's because it's using more than 480mA. The difference is coming from the battery.)
gianfranco
