Issue with zenfone 2 and reliance?
Srvgodara
12
My friend got his zenfone 2, everything is working fine exept the 3G network on reliance are pathetic. He tried everything but data connection is useless. He tried using his sim with other devices and they worked fine. Any of you guys facing the same issue?
From our AC Review of it (T-Mobile US) he didn't have an issue with speeds (LTE) on the Zenfone 2.
Ya .. APN is fine... 3g is connecting but speed is nothing..I mean 50 kbps or 100 max
Recommend to use our ASUS app called ASUS Support/Assistance. There are several helpful tips regarding basic troubleshooting techniques for your device's software and other parts such as Battery, Sound, Display & Touch, 3G / LTE / WIFI / GPS. For online assistance please see Zenfone Quick Service: ASUSTeK Computer Inc. -Self-Service-
Sincerely,
ASUS_USA
I am also facing similar problems on reliance 3g H icon show up but real speed is 2g
Hey - so I'm pretty sure this is a trolled post. We should let it go. The Zenfone almost every account has performed fine.
This is the real problem... 3g is not working fine.. The phone has replaced but the issue is still there... So I want to know if it is a soft issue or faulty batch?
I think it hardware issue zenfone isn't compatible with certain 3g network
I am also facing the same problem since 1 week when i got my new zenfone 2. I talked to the engineering team of Reliance. Nothing worked out. Meanwhile I had given for porting to IDea. Reliance ppl called again and told me to go for 32 bite new Sim.
I had lost the patience by then and m just waiting for idea to port. U can try the 32bit SIM
Regards
RAP25
