Issues with FC's when using dasBAMF? any ideas
ssethv
ANDROID OBSESSED
Dec 4, 2010
1,582
371
OK... so I am running dasBAMF gingerRemix 2.1 and love it... HOWEVER. I am having some SU issues. whenever I try to use terminal emulater, root explorer, or superuser app; I am only able to use them once. If I try to use them again, I have to run fix permissions in the DB toolkit in order to use those apps again.. Luckly I am able to use SuperManager app. I was just wondering if this is a known bug or if anyone else is having issues too. thanks for your help
I dont have those issues (i switched to 2.1 remix for the last few days). Didn't have those issues on rc3 sense either.
I did have similar issues with 2.0 betas, tho, and I just ran fix permissions and that took care of them, i think.
Reactions: ssethv
I was wondering if you have had the same terrible battery life I have using Bamf GingerRemix v2.1 that I have? along with slow battery?
Have you heard of any kernels we could flash to improve out battery life or quicker charging?
Sent Using Tapatalk
RichardDixon
