Issues with the Verizon S7 edge.
zainsikander32
66
So, guys I've spent a day with my Verizon S7 edge in Gold. I've noticed a few things. So far my Phone has restarted for no reason whatsoever twice. Has the happened with anybody else? I've also had all my apps that I transferred to the SD card disappear on me after it restarted. They reappeared after I went into settings and then applications manager and deleted one of the apps I remembered and was appearing there inside the list.
It might be your phone... You may or may not have to get a replacement. Did you reset it yet?
It hasn't been as serious as an issue for me to want to Factory reset it or replace it. It's just so frustrating setting it up in the first place that I'll try and live with it. I'll wait a few more days to see if it happens again.
I have a Verizon edge and it hasn't rebooted a single time. Have had it since Monday.
May be the sd card and moving some apps there is causing this? I could easily imagine some app not handling it well and causing some issues and in turn the phone going crazy.
Another update. My phone seems to disconnect from the Wi-Fi for a few seconds and then reconnects. Never happened with my S6 edge.
I we get replacements, what happens to our watches and vrs? Do we have to reregister?
I can't download any Google Apps on any wifi connection and I can't use any Google apps on any wifi i.e. Youtube, Music. Using Play Store Version 6.0.5.
Curt RFD
