It begins...
I got the update today!
Google Wallet tap to pay, still no go..
I have not actually tested the Google Wallet tap to pay but the setup process asked me if I want to enable tap and pay, which I did. Now, Google Wallet shows under Settings->Tap & Pay as the default app for NFC tap and pay. I think it should work. I'll test it later tonight
Already having an issue when hitting the home button. It seems to be double tapping when I hit it. On action launcher, it will take me home then open the so drawer. On Nova, it will go home then zoom out to show all the home pages....
So, what can I expect from this update? Any new features, etc? Just curious because I am completely happy with 4.2.2 on my MAXX
I am getting the same thing with Nova. I wrote the developer. Hopefully there is a fix cause it is aggravating. But if I don't use Nova I don't get the pretty translucent app drawer. And if I don't use Nova I am stuck with the Google search bar on my screens.
I'm not experiencing exactly the same but similar nuisance. If I open an app not from the default screen then, before the update, hitting the home button would close the app leaving me on the same screen from which the app was opened; now, hitting the home button closes the app and navigates to the default home screen.
On Nova you can change what the home screen button does so it doesn't double tap it.
I don't think it's a problem with the launcher. Even on the default home screen, instead of just going back to what page you were on. It goes to the default when instead.
SUPER ANNOYING!!
SUPER ANNOYING!!
Yes, annoying!
Still sunny here in California :(
Posted via my awesome, longer lasting phone than yours aka droid MAXX
Here are the Nova settings to fix that double tap action.
THANK YOU KEVIN at Nova for your quick response!!
Nova Settings > Gestures and Buttons > Home Button > None
- - - Updated - - -
Serious?
When updating to 4.4 was everything erased from your phone like a factory reset? I don't remember if that was the case with the last update. And it shocks me that all the blue was not removed in 4.4. Bothers me, actually. I expected it to look just like 4.4 on the nexus products.
Nothing gets erased - all your apps, media, and settings remain intact.
I had to cut off home preview because of this.. hopefully a new update is coming soon
I hope you guys who are having problems are reporting it on the Moto forum if you're part of the soak test.
The problem with pressing the Home button doing funky stuff is a bug the Droids are having with Kit Kat. You shouldn't contact the Nova developer about it because it needs to be addressed by Moto.
Tap to pay works but you have to enable NFC first. I did my first tapping to paying to buy some gas. Woohoo!
Not everybody in the soak got access to the forum because of the # of people in the soak. or so I hear...
Well the Bluetooth is now working properly again, I am quite pleased about that. Google Wallet tap to pay, still no go... Was an advertised feature of kitkat.
Other then that I have on seen a couple of minor changes but I have only had it for a few hours.
Funny, my experience is exactly the opposite.
My BT remains broken. The difference is now it knows it is not connected, which is an improvement. I was streaming music on my commute today which reminded me how well my BT worked with the initial OS.
I installed wallet and it looks like tap to pay should work. It pulled my old receipts and card data in. I will confirm in the morning when I make my normal coffee run.
Sent from my XT1080 using Tapatalk
The soak will probably be going on for another day or two. Anyone who is having any issues with the update the next couple of days, feel free to PM me what the problem is if you don't have access to the forum and I'll report it there for you. Moto needs to know about the bugs so they can fix them.
Jackwills2567
