It's finally here!!!!!!
Its Verizon...there will be no freebies.
g2
Yes it does use your data. I just chatted with vzw rep.
Your Chat Session ID is RT18955092280.
My name is Katrina, how may I assist you?
James: When downloading a ota update does that use your data?
Katrina: Hello James
Katrina: Yes, it does use your data.. We recommend doing OTA updates over wifi. :-)
James: Thanks
That's what I'd surmised.
g2
James: Thanks
Personally, I'd believe their documented FAQ over what a rep says. :)
Edit:
They do free service based texts that don't count against your text allowance, same thing with OTA's and your data allowance. Honestly, I've NEVER heard of anyone being charged overages because of an update. Can you imagine the outrage if they did? :eek:
The ONLY time you may incur data charges with an OTA is if you're roaming off Verizon's network, which is the only time their update documentation (see http://support.verizonwireless.com/support/system_update/galaxynote2.html) mentions using Wi-Fi to get the update. :)
To answer your question I have not noticed any issues with my phone
I got it this morning, I noticed the battery drain a bit faster that i had to swap it out right now. Now its stuck in the galaxy note screen. :'(
If Google? releases Over the Air (OTA) updates for my device, will I be charged for data usage?
No, you won?t be charged for data usage on any OTA updates you receive on your device.
Google and the Google logo are trademarks of Google, Inc.
Sent from my T-Mobile LG Escape running 4.1.2 using tapatalk 2 (Central n ohio Austin IL)
In my experience Verizon will take every possible opportunity to charge you (comparatively speaking) if the opportunity arises.
CM on OgPro
I can't stand vzw but even I know that they don't charge for ota updates.
Buka Blokir BRImobile
