I just did it and my Bluetooth does not work?
you may have to try a different Kernel, this will require rooting , flashing CWM via odin , getting rom manaager and flashing the kernel
Just took note. Bluetooth is nonfunctional for me.
Are the DJ05 a good fit with this build? I have all of the stupidfast versions and was fond of 1.54 and 1.76 just wanna make sure I don't scramble something.
I found my answer in XDA - Yes... flashed stupidfast 1.54; Bluetooth and haptic feedback now active.
will this update wipe out apps, widget layouts and contact?
I suggest doing a Clockwork Mod ROM backup, flashing DL09, re-root (One click worked just fine for me), reinstall Clockwork, and reload your ROM backup. Quick and easy and nothing too dirty.
As promised, I am releasing the DL09 Odin, now that its official that it is the OTA.
No warranty or guarantee implied, this gets flashed via Odin 1.30 in PDA section (or unzipped and flashed accordingly in heimdall). It is stock, nonrooted, and bloated all to hell. I HAVE NOT TOUCHED THE ROM CONTENTS.
This technically doesn't require root to use, but it does require a user who knows how to perform these more advanced things.
http://adrynalyne.us/files/odin/DL09.tar.md5.
Mirror
http://hbspeed.com/android/DL09.tar.md5
My host sucks, I know, so mirrors are welcomed.
Enjoy!
This is a stock Odin, not a dump from my phone. There is no reason bt should not be functional after a flash.
Had the same issue with the three part DJ05 I flashed prior it booted fine and worked without issue just did not have haptic and bt. Flashed a new kernel and it worked fine.
Flashed in as directed, rooted, flashed CMW and that is when the haptic went away, I did not check bt until I saw a post here.
Hey everyone. I read this forum like crazy and this is my first post, but i am having a strange problem after Odin flashing dl09. After Odin (which went without problems), I used the 1-Click root method and it went fine and then used titanium backup to freeze bloatware. After doing all this i went to change my ringtones. The default phone and notification worked fine from the settings, though the messenger, gmail, and twitter app are having problems. Each one, I go into settings push 'select ringtone' and they pause and then prompt to force close. Facebook works when i change the ringtone. Other than that they work fine as far as I can tell. I then went and unfroze everything in titanium backup to see if i froze something that caused this (no change), I restarted the phone, wiped the cache. At this point I am wondering if it is the dl09 leak but have searched the forums and cant find anyone having this problem or anything like this. Any thoughts would be appreciated.
I did a factory reset on my Fascinate & Now I cant get to the home screen. All I get is FC & this Message.
Help Please...
