I've got an HTC One (M8), you have questions. Fire away.
Re: I've got an M8, you have questions. Fire away.
Can it use its display for any notifications, without doing any sliding moves or knocking on display first?
It does that when you have the dots case on.
I'm thinking of getting the developer version. Is the developer version fully compatible with T Mobile radios?
Is the charging port still off-center on the bottom of the phone?
Thanks Phil. What kind of notifications can it display while using that case? Or you don't have it? :-/
I have it. Time, weather, date, calls.
I'll do a post on Wednesday.
Will the developer edition support T-Mobile's LTE fully this time around?
Can you change the style of the fonts?
Full network specs:
GPe is ... (I assume unlocked/dev will be this, too, though we'll have to double-check.)
- GSM/GPRS/EDGE: 850/900/1800/1900
- WCDMA: 850/AWS/1900/2100 with HSPA+ up to 21Mbps
- LTE: 700/850/AWS/1900 (B17/B5/B4/B2, carrier aggregation B4+17;B2+17), + roaming 2600/1800 (B7/B3)
NETWORK (2)
2G/ 2.5G - GSM/GPRS/EDGE:
850/900/1800/1900 MHz
3G - WCDMA:
EMEA: 850/900/1900/2100 MHz with HSPA+ up to 42 Mbps
Asia: 850/900/1900/2100 MHz with HSPA+ up to 42 Mbps
AT&T: 850/1900/2100 MHz with HSPA+ up to 21 Mbps
Sprint: 850/1900/2100 MHz with HSPA up to 14.4 Mbps
Verizon: 850/900/1900/2100 MHz with HSPA+ up to 14.4 Mbps
Tmus: 850/AWS/1900/2100 MHz with HSPA+ up to 42 Mbps
3G - CDMA
Sprint & Verizon: 800/1900 MHz
4G - LTE:
EMEA: 800/900/1800/2600 MHz
Asia: 700/900/1800/2100/2600 MHz
AT&T: 700/850/AWS/1800/1900/2600 MHz
Sprint: FDD 800/1900 MHz , TDD 2600 MHz
Verizon: 700/AWS/1800/2600 MHz
Tmus: 700/AWS MHz
How much can you zoom in photos taken by the dual camera, in the gallery app? Apparently I can't zoom too much with the 2013 HTC One gallery app. It's important for me.
Do you have access to the Verizon model? How does it compare on signal strength vs the G2 or Motorolas ? I wonder if the metal is hurting RF performance?
Notification LED, and where is it on the phone? Thanks.:p
Hey Phil,
How are the charge times? Same as HTC One or faster?
Sent from my T-Mobile Note 3 using AC Forums.
Have you used the Fitbit app at all? I did not see mention of this in your review, I think it was Engadgets? Wondering how it works with the new HTC api to let it track without wearing another device.
I have, actually. :) Tracks your steps just like a pedometer would. More on that later.
Hey Phil,
Faster -- and it'll get even better once we have a proper Quick Charge 2.0 charger. (Read the review for more on that.)
wsw293200
