LabRat-517
- Oct 27, 2012
- 7
- 0
- 0
I still dislike not being able to put apps on sd card.
I don't like that either.
Let us put our stuff where we want to.
I'm going to go ahead and say that neither of us are crazy and it did get bigger. Really not a huge deal, but glad to know at least it appears that way to others.
Overall I'm liking the feel of Jelly Bean, I'm a fan of the effort that was put into "Project Butter". While I know someone wasn't a fan of the new folders, I actually like them. The larger icons do a good job of triggering what some of the items inside are.
I wish Google Now would allow me to enter College sports! And I wish you could map Google Now to the double press of the home button instead of S Voice.
I'd like to see that as well. I wouldn't be surprise if that gets added as Google Now continues to evolve. I'm liking it so far. I just through a button on my home screen for Google Now. Someone mentioned adding it to the Lockscreen so that you can swipe directly into Google Now.
Google now is on the home button...long hold. It's the middle button.
Sent from my SPH-L710 using Tapatalk 2
Man Loving the all the new features witch of course all of you guys have mentioned. Battery life is slightly a little more higher and I did notice on the stock browser there is now a back and forward arrow witch is cool and it's even more faster and flash still works that's a plus. Also hopefully in the future with the next realese they will bring back the wifi arrows and make the screen a little more darker not feeling the gray no big deal. Everything overall is just buttery smooth i have no major complaints. The GS3 was already a beast this update makes it a beast on steriods lol.![]()
I also can't launch it this way. I want to because it reminds me of webOS and its easy to access from any app.Swipe up doesn't launch Google now for me in any instance.....
I share this gripe. I would've bought the 32gb version instead of spending on my sd card. While it's an issue, it's not one that I have struggled with.Most have moved on making your gripe a none issue. Please join us... MOVE ON!
After completely re-formatting my SD card and doing a factory reset on my phone last night, the battery life is on par if not, better than ICS!! I suggest everyone start backing up there files and doing this if you have any type of battery problems or weirdness on your S3 after your update.
I have done a factory reset today, although I had installed JB after a factory reset but I haven't reformatted my sd card and don't understand the correlation. Can you explain how you reformatted and what you did with the files you needed to save in the meantime? I have clockworkmod backups and a crap-ton of pictures and music that I don't want to lose...give me a tutorial?
Copy all of your pictures, music and files to your computer. Install EaseUSPartitionMaster on your computer. Insert card in card reader. Open partition master. Choose go to main screen. Choose you sd card. Choose format partition on the left. Choose your file system (fat32). Choose ok. In the upper right corner choose apply.
When complete copy only what you need back to the phone. You should always store you pictures on your computer and not your phone. If you want to access your pictures from your phone there is always dropbox. As for music and other files you need. copy it back to your sdcard and re-install in your phone.
Thank you!! I'm considering getting a bigger card so I will do this tomorrow and to the new one.
I have absolutely no idea which files the phone needs me to keep in the card, is it safe to keep just the music and photos? I know I need my backups... will changing the format of the card mess up my backups?
