I've got the Verizon Xperia Z3v, you've got questions. Fire away!
Did anyone visit a Verizon store to see if they had any in stock? When I do a Find in Store, none have any in stock.
I will say that when I went to get mine, she took almost an hour actually selling it to me because when she scanned it the system said it wasn't eligible for sell, like it hadn't been added to their inventory. So that may be the issue with your local stores too.
That's probably it. I'm torn between this and the Note 4. I like my Note 3, but often pop the SIM into something else because of the size.
Same as Moto X. All the new VZW phones are Tri-Band, for another expansion in their LTE coverage & similar to Sprint Spark devices, need the VoLTE eCSFB software updated & enabled. Sprint cant do it yet as they still don't have band 25 up and running & 42 is a mess, w the software needing a re-write for the new new radio towers.
Anyone know where to find some good cases for the z3v? Picked up the phone, but verizon had nothing for it. Thanks!
1. Micro or Nano SIM?
2. Did you get a chance to test the multi phone photo thing. I don't remember the name, but it's when you can pair up to 3 phones to shoot from different angles.
3. If you are done with it, can I have it. I'll send you some gum. :)
Has Sony said how Remote Play will be released? Will it be an app in the Play Store or will they release it through the Xperia Lounge? Will you be require to be on the same network as your PS4?
Looked like it's a PlayStore app.
I would love to know the answer to the tail end of this question, "will you be required to be on the same network as your ps4?"
Sony is making it sound like the answer is yes, however if I remember right they said the same when it came to the release of Remote Play for the Vita, yet it works outside of home WiFi.
Do you have voice and data at the same time?
I would think it works. I live in an area where I have constant 4G LTE and Voice and Data has always worked for Android phones on Verizon. When on 3G CDMA it is not possible but, hey Phil can answer for sure...lol. I have had HTC Rezound, Droid DNA and OG Moto X.
It might technically work outside of your home WiFi but I'm guessing it really is unusable for the most part unless you are on the same Wi-Fi network.
Did the verizon z3v come with any headphones? Also how is the vibration on calls on this phone. When my lg g3 is on my desk I can not always hear my phone vibrate when I get calls at work, it is really a very weak vibrate.
I was the same way when I got there at open on that Thurs. I had to wait while the checked it into the system. Even then my store only had 4 of them 2 black 2 white.
No headphones, vibrate kind of weak. Haven't looked to see it there is different vibrate settings like my gs3.
As far as I have read about this you will have to be on your home network for the remote play to work. The Z3v comes preloaded with a Playstation app. I have already paired it to my PS4 but nothing really exciting to do yet as remote play hasn't launched. I assume it should be pretty quick though now that PS4 Version 2.0 dropped this morning.
Nothing good that I know of yet. The store that I went to did have a tempered glass screen protector (which I love because it doesn't have that screen protector feel) and a generic rubber case came bundled with a new car charger. I am anxious to see some accessories come out for this phone.
r3dpuk3
