Jabra Wave with A2DP help
Xanth269
511
26
Hello all,
I got a Jabra Wave and it says it will connect to A2DP devices and I searched and found out the 4.2.2 fixes the issue. I use AOKP JB 1 Build 5 ( JB 4.2.2)
The blue tooth for phone calls works great but I have been unable to get audio to stream.
I tried a A2DP program from the store but it too did not work.
Am I missing something? I read a review of the Jabra Wave and writer wrote it worked on his GNx.
Thanks all
EDIT- I did just install a mono BT app, it sends music to the BT now, so does this mean its only a mono headset and I will not get stereo out of it?
kankuraon
