Jelly Bean 4.2 Camera
Check the third thing in the third post.
Sent from my Nexus 7 using Xparent Cyan Tapatalk 2
Still not working, took old file and renamed.. Bak and copied new apk over. Restarted and cleared both cash, rebooted and still says 3d close..... Sry to keep bothering you.
For all those having rendering panorama bug at 99% and not having sphere viewer icon, try setting language to English USA..it solved for me, I hope somebody can fix that
dmmarck: Rendering of PhotoSphere works only when system language is set to US English, otherwise gallery generates error at the end of rendering.
Here is the logcat: http://dl.dropbox.com/u/26872856/error-log.txt
I think that this is useful section but I am not a programmer... :
Code:
11-01 08:30:58.499 E/AndroidRuntime(8973): FATAL EXCEPTION: AsyncTask #1
11-01 08:30:58.499 E/AndroidRuntime(8973): java.lang.RuntimeException: An error occured while executing doInBackground()
11-01 08:30:58.499 E/AndroidRuntime(8973): at android.os.AsyncTask$3.done(AsyncTask.java:299)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.util.concurrent.FutureTask$Sync.innerSetException(FutureTask.java:273)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.util.concurrent.FutureTask.setException(FutureTask.java:124)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:307)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.util.concurrent.FutureTask.run(FutureTask.java:137)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1076)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:569)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.lang.Thread.run(Thread.java:856)
11-01 08:30:58.499 E/AndroidRuntime(8973): Caused by: java.lang.NumberFormatException: Invalid double: "23,283013"
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.lang.StringToReal.invalidReal(StringToReal.java:63)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.lang.StringToReal.parseDouble(StringToReal.java:269)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.lang.Double.parseDouble(Double.java:295)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.lang.Double.valueOf(Double.java:332)
11-01 08:30:58.499 E/AndroidRuntime(8973): at com.google.android.apps.lightcycle.util.MetadataUtils.writeExif(MetadataUtils.java:211)
11-01 08:30:58.499 E/AndroidRuntime(8973): at com.google.android.apps.lightcycle.util.MetadataUtils.writeMetadataIntoJpegFile(MetadataUtils.java:137)
11-01 08:30:58.499 E/AndroidRuntime(8973): at com.google.android.apps.lightcycle.panorama.StitchingService$StitchTask.doInBackground(StitchingService.java:444)
11-01 08:30:58.499 E/AndroidRuntime(8973): at com.google.android.apps.lightcycle.panorama.StitchingService$StitchTask.doInBackground(StitchingService.java:345)
11-01 08:30:58.499 E/AndroidRuntime(8973): at android.os.AsyncTask$2.call(AsyncTask.java:287)
11-01 08:30:58.499 E/AndroidRuntime(8973): at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
11-01 08:30:58.499 E/AndroidRuntime(8973): ... 4 more
11-01 08:30:58.514 W/ActivityManager(307):   Force finishing activity com.google.android.gallery3d/com.android.camera.Camera
Same to me on 'Polish' language. Change it to English (US) and it works! :-)
Hey dmmark,
Thx for great work!! But also in german the gallery crashes when rendering at 99%. Setting to english works for me.. May this be fixed?
Awesome work, really!
Here is my latest flashable zip.
It contains all the files provided by dmmarck.
  • GalleryGoogle.apk [The actual Camera and Gallery]
  • GmsCore.apk [Sphereview]
  • libjni_filtershow_filters.so [PhotoEditing in Gallery]
  • libjni_mosaic.so [Panorama Photo]
  • linlightcycle.so [Photosphere]
The GalleryGoogle.apk is the modded one from androidpolice.
That make the working/not working list look like this:
1. Panorama.
2. Photosphere. (requires gyroscope?)
3. Photo editing.
4. Sphereview.
5. All ordinary camera/video functions.
6. Should* work on ALL phones.
For gallery to not FC when rendering Sphere shots, change your system language to English (United States).
This will also make Sphereview work!
Here is the new zip. Please do not mirror unless it's absolutely necessary as I wish to keep track on how many downloads I get on this file.
Dev-Host - 4.2Camera_t04.zip - The Ultimate Free File Hosting / File Sharing Service
*should doesn't mean do.
Well, it DOES NOT work on HTC One X with CM10. liblightcycle.so crashes after taking first shot. Eh...
champkbillu
