Jelly Bean 4.2 Camera
Added the two libs, no more FC's
But when I try to use the Photo 360, getting "Sorry, your device is not yet supported"
Guess I'm out of luck! :'(
TMO GSII T989
No u aren't lol just use the zip file instead of the plain apk. Use it through recovery. Said the same thing to me at first haha
Sent from my EPIC WHITE SGS2 Rockin CM10 4.1.2 using Tapatalk 2
OK,Dude i have done everything
Place GMScore.apk,GoogleGallery.apk in system/app
Place Lib Files in system/Lib
I even change my build.prop(changed the name and the brand of my phone to Galaxy Nexus/Google)
And it is still Force Closing
I am Using LG Optimus 3D with Stock Gingerbread 2.3.5 rom,It is also rooted.
IF i have to flash some zip files with the App in them please tell me how to do it,because i am new in Android :)
The problem is that you're installing an app meant for 4.2 on a phone running 2.3.5. Your Android version is old. So much has changed in the Android system, especially from gingerbread to ICS.
Sent from my 9100G, running the amazing CM10 / Codebox / Slim Bean, depending on the day ;)
Yes i know that my Android is old,but in some forums it says JellyBean/ICS/Gingerbread
But then i got zip file in which there are 2 folders Meta-inf and System
So i tried to only the system folder,then i rebooted and after that the 2 apps(Gallery and Camera) didn't appear in the menu
But they are in the system/app
Did you fix permissions?
yes i put them both on RW-R-R
I even tried with max RWX-RWX-RWX
And it still force closes(not the app from flashable zip,but the one which appears after putting in system/app)
That's the problem u gotta use the zip file through recovery
can you please tell me how and provide me a link?
And
Is there any risk for bricking the phone?:)
And all u do is go to the file in recovery and install it and u are done
I cannot find a working link,please provide me one.
In recovery i got an option-install zip from card.Then i Got 4 options
-Choose Zip from sdcard
-Apply /sdcard/update.zip
-Toogle signature verification
-Toogle script asserts
-Choose zip from internal sdcard
Which option i need to use .
And one more thing
Is there any risk if bricking?
Its on page 3 lol and choose install zip from SD card
Has anyone noticed that the camera in 4.2 jelly bean is zoomed in by default compared to 4.1. I have to back up about 2 feet to get the same angle and my gfs galaxy nexus on 4.1. Is that a bug?
Haven't really had that issue or didn't pay attention lol
Yes actually runs 4.2 as good if not better then 4.1.2. would of replied sooner But was out of state. video works and so does the sphere but sphere is slow.
Sent from my SCH-I500 running android 4.2 using Tapatalk2
heritagevines38
