Juice defender?
Can someone please confirm whether or not juice defender is still being developed?
The same sent directly to the developers have never been answered.
What's the last updated version? I still use JD+.
Sent from my HTC One using Tapatalk 2
I've purchased Juice Defender Ultimate for my past Evo 3D, and it worked great. I've also ran it on my HTC One.
It's good, but I think the user interface (U.I.) is outdated and needs work done on it. Also, check to see the last release dates, and you'll notice that the last update was back in 2011. For this reason, I decided not to continue using it, since the developer/s obviously don't want to improve on it.
Check out I believe it's called "DU Battery". It's what I'm currently using it and actually like it alot. It also has a higher rating than Juice Defender. Best of all, it's free. And the paid version is like 1 buck.
Not that it makes matters any different, the last update I see is January 2012. Although I must say it still works like a champ on my Nexus 4.
JuiceDefender - battery saver - last update - January 15, 2012
JuiceDefender Ultimate --------- last update - December 13, 2011
JuiceDefender Plus -------------- last update - December 13, 2011
JuiceDefender beta -------------- last update - January 9, 2012
Just saying
It seems that Juice Defender is dead. Too bad because Juice Defender works really well on Android. Or at least it did. On my Note 3 it would nearly double the battery life. However, recently it started crashing (on my Note 3 and my wife’s Note 3), and when that happens it’s disabled when it restarts. But it seems that the developer has packed up his crayons and gone home. The Web page is gone and there’s no active contact links for the app even though it’s still available in the Store. I’ve tried a couple of other “battery saver” apps but they didn’t work nearly as well as Juice Defender.
Anyone else using Juice Defender and seeing this? Have you figured out a way to keep it running?
Can anyone recommend a similar app that works well?
Annuji202
