Just installed Nougat
What do you mean by disabling app drawer? The Nexus launcher has a redesigned up arrow in place of the traditional App drawer. More icons in the dock bar which is a really nice feature.
Any major changes from Marshmallow, or is it all a fuss over nothing?
From what I read on the Verge doze mode didn't really changed that much so I think it's pretty similar to Marshmallow. Haven't tried it yet, though.
Ability to run two apps on screen at the same time, better notifications and quick settings. Also, "doze on the go," where the phone can now stay in Doze while the phone is in your pocket/purse. Before the phone had to be completely stationary to go into and stay in Doze.
Can you post a screenshot? I don't see any changes on my 6P outside of the notification toggles.
how do I disable the app drawer on the 5x?
Surely a screen shot of the Nexus launcher with the redesigned interface.
I hope that helps a little bit.
I want all the apps on the home Screen Ala iPhone. I have the nexus launcher, I had to download the apk
Would you use the stock launcher or Nova Launcher?
I'm currently on the beta programme, is the update any different? If it's not any different I won't remove the beta version.
Just stay in the beta program and they'll keep pushing new builds in the next few months. Was an article recently covering a Google blog post outlining the plan.
Google had already said there wouldn't be much changes between the DP5 and the final version of Nougat. That will be for the maintenance release that will come out when the new Nexus phones are released. I also expect a "major" camera update at that time.
There should be an option by why anyone would want the homescreen to auto rotate on a phone is beyond me. Apps (like YouTube) can auto rotate by themselves.
Landscape on the phone helps when you mount the phone in landscape orientation in your car...
Right now I'm Using Nexus launcher so that I have more apps in the dock bar which is really helpful.
Also, when the heck are we getting a raw image mode? Google was playing with that years ago. I know third party camera apps can do it on the Nexus phones but still...
I've played with a few that give you a .dng file and I settled on Manual Camera. I like it but when the phone is saving a .png+.jpeg, 25Mb, it takes a few seconds. If I get anxious and click a few times it finishes download, shoots again, and so forth. I suspect the number of Nexus owners who want RAW files is a small niche and it isn't a high priority for Google. I think the total number of cameras capable of produce a RAW file is still pretty small.
Actually, you can just use the quick setting tile to trigger the autorotation or force portrait. The contents of the homescreen will auto-rotate as well if you select the option. Or you can go to Display in the Settings menu and select it as well.
Like I said zooming out the screen in dpi settings the developer options is really cool though. More space for icons and the apps and keyboard are also reformated to fit to the screen now.
I'm 75-years old and my eyes aren't what they used to be. I still drive without glass and can't tell a cow from a fat person. Since I don't want to hit either one, it's okay, though. I like being able to have larger fonts and larger icons so I have a shot, in good light, of reading something without my reading glasses.
Options are always good to have.
That's true. I've always had 20/ 20 vision. You make avery good point though.
koltyn
