[KERNEL] Franco
So what settings are you guys using in Franco's app?
I changed CPUQuiet Governor to runnable per Franco's advice after I started getting reboots with a commit he made on r5. Besides that, Turn Logger off and Wi-Fi PM_FAST.
I am on R21 with the ability to scale GPU frequency. Where can I tweak the GPU frequency? Within the updater app or is there another app way to do that?
Got it on the 484Mhz clock by editing the gpu_oc file
Originally Posted by franciscofranco on XDA-Developer View Post
Just released r20 with some nice goodies:
* GPU overclock interface. Now you're able to choose which frequency you want your GPU to run:
To check the frequencies just do this: cat sys/devices/system/cpu/cpu0/cpufreq/gpu_oc
The default clocks are: 416 416 416 380 332 285 234.
To change to other clocks just do this: echo X X X 380 332 285 234 > sys/devices/system/cpu/cpu0/cpufreq/gpu_oc
Substitute the X with 484, 520, 550, 600 or 700 if you'd like. Be careful that on higher clocks the device might get extremely hot and unstable. You're on your own.
alejandro109322
