Keyboard accuracy
Any updates on your situation, OP? I can get how accidental screen touches may be a thing; but that wouldn't affect predictions and autocorrect, like you mentioned. Hopefully things are getting better for you!
Nope. Still getting very strange predictions/results. I have just learned to do my swipes more slowly and deliberately than before. And reread before sending a message. Maybe it is a Android 12 thing and not my P6. I cannot tell because none of my old phones updated to 12. Gboard versions are the same.
It's happening on my 5a running Android 12. I had my 5a for only a week or so on Android 11 before it updated to Android 12 on the September patch. I don't remember typos happening that first week or so I had my 5a. So I think it's an Android 12 problem.
Don't laugh but I install BlackBerry virtual keyboard on all my pixels. With that said, no more or less typos on my Pixel 6 vs other pixels I've used. I do switch to GBoard for voice typing now with it being instantaneous. I've tried using it for typing and can't do it. (No swipe up predictions).
I use SwiftKey, and have for years. But I, too, switch to GBoard for voice typing. Never for regular typing though.
This was the link provided within the CrackBerry forums by Conite(a trusted moderator)
I don't think Conite is a mod for Crackberry, but for me he is the most trusted, knowledgeable, and helpful of any of the members. He's helped me a lot.
Bah! Thank you for keeping us updated! At least you've found a workaround of sorts. Hopefully this gets resolved soon!
100% of the time I want to type the word 'some' and it comes out 'dinner'. God comes out as good. Try it.
Extremely annoying. Ready to go back to tapping texts out with thumbs again.
On my Pixel 6 some tends to come out as dinner after "for" or just done or some. As in "for dinner reason". Done tends to fine after just. Fine tends to give. Etc. Also for is often due.
It was dumber yet better in the Pixel 1 and 2.
I went in and resized my keyboard. I still have issues with typos more than my Samsung but this did help me somewhat.
How do you resize the keyboard? I have a slight case of double vision and occasionally strike the wrong glass key.
yettispagetti23
