kit Kat update problems?
jrsharp70
841
Anyone else getting bad WiFi signal, s note problems, and battery drain?
I keep having to restart.
This is most common in kit kat. Go to recovery and clear cache and data/factory reset ..
clearing data will remove all the downloaded apps.
if you don't want to clear the data then clear the cache
stonefruit
