Kit Kat "use ART" breaks xposed framework?
jinjin12
169
i've heard enabling ART on android 4.4 while using xposed, ends up breaking xposed?
is this true? xposed don't work with ART and only dalvik?
Yeh, sorry pal... I asked this question on another forum and they said it only works on dalvik. In the xposed framework forum they also say that it won't be supported for a very long time, so nothing to even look forward to... :(
Sent from my Nexus 5 using Tapatalk
that sucks :(.
As others have said, ART will not work with XPosed. The reason is, that XPosed works by modifying system elements as they are started and loaded into memory. ART completely changes this, and thus will require a nearly entire rewrite to Xposed before it will work with it.
Posted via the awesome Nexus 7
reblkari666
