Lag fix
Status
Not open for further replies.
No I rooted and did the RyanZAEXT2LagFix ALPHA 1 from this site. I did an uninstall and am currently reinstalling it.
No, I'm rooted and I installed the RyanZAEXT2LagFix ALPHA 1 from this site. I just did an uninstall of RyanZAEXT2LagFix ALPHA 1 and am currently reinstalling it.
I'll try it. I just got a 792. These scores are worse than what it should be stock!
Update: I don't see a voodoo for the Fascinate on their website.
I did what it said, is there a way to confirm that voodoo installed. The first boot did not take forever like they said it would. I didn't get any errors in the install and I did rename it to Update.zip. I got a score of 832 is all.
Well if you're getting 832 then you're not on voodoo. Did you do the 2nd thread I just posted? You need to do that and NOT name it update.zip
Ok I think it's working. I heard the voice telling me this could take a few minutes. I'll post my score when it's all done. Fingers crossed!! Thanks again for all the help.
i cant seem to find where your kernels are in your signature how do i get to that?
Updated PLEASE READ COMPLETELY
__________________
Samsung Fascinate Rooted w/ voodoo lagfix
Kernel: D02-Kernel-LV-1250
Helpful Links for the Fascinate
1 Click Root - My Voodoo Lagfix Kernels - Back To Stock
There are 3 links in your signature. None of them link to anything that would require a google sign in and there are no kernel's to be found. The "My Voodoo Lagfix Kernels" simply links to this thread's first post.
Is there a more thorough explanation of what low voltage and standard voltage mean? Do they have different clock speeds as well? I'm looking to see the benefits of the fix and nothing more. I'd like speeds and voltages to stay exactly the same as they are when I opened the box.
Thanks!
Ok so i can't seem to get this working. tried the install method posted here and xda developers. I removed the ext2 lagfix and through quadrant the phone is doing as it should. When i put and this may be the confusion but i have tried both the .zip file or the two folders on the root of the sdcard then through rom manager go to clockwork recovery and try to install but nothing. i believe it says couldn't find update zip and then after two tries just reboots itself. I have been trying to use the D012 low voltage kernal. Haven't tried the other one. In that regard though what is the difference between the two of them? Any help would be appreciated and thanks.
Hey, so I just finished rooting my phone per your instructions, and now am trying to install the lagfix. This is my first time rooting, and I cant seem to find the link to actually download the voodoo kernel, and am not entirely sure which one i should download when i do find it.
I went to the links in your signature, and could not find it, unless you want me to go to Voodoo's website, in which case, which version do i download? It does not have voodoo 5 up for the fascinate.
Thanks
Status
Curt RFD
