Latest/best one click root method for the TB?
Before starting this post I want to sincerely thank trter10-2 for all his help and courtesy with all the members of this great forum. You have been very helpful.
I used your method to root my phone 1 month ago. I had the .5 version in my Verizon TB and I needed to downgrade in order to Root so I used the no downgrade or data wipe. I worked flawlessly.
My problems began with the Verizon OTA. One day when I woke up the phone was with the white triangle and the blue android. I read the forum and was able to use the recovery. Thankfully I wiped cache partition and everything went back to normal but the OTA kept on coming and coming every single day.
I decided to use the $2 app that worked very well (I used it as I am not very savvy with rooting and stuff).
My problem is that now my phone is Stock and I wanted to update the software so I could get the last firmware (2.11.605.19) and then rooted the phone.
As I mentioned my actual software is the 2.11.605.5 version. I started to pull down the software update and every single time I try is giving me a download error. I press on check new, it shows a new one (I can not see which one is pulling down) and when I hit OK it gives me an error. (Download failed).
I have tried pulling out the battery. Charging it to 100%. restarting it and nothing.
Do you know what could be happeining? Any suggestions on what to do? Thank you again.
I'd say reroot and use my otablock :P
Sent from my ADR6400L using Tapatalk 2
Thanks for the prompt response. I thought about that but as Verizon is going to air a new OTA with the Ice cream sandwich I thought I could use the normal OTAS for that. Now If I root I wont be able to get it if it comes out. I just rooted to delete all my bloatware (which I have back as I used the TB Unroot app).
Do you thing something might be blocking my phone to receive OTAS?
Thank you again.
Thank you again.
Not sure what could be blocking them.
You could just flash the leaked RUU but it wipes your data
birdsong2000
