Launcher Pro problem.... :(
tobrizonwireless
Active member
Oct 14, 2010
25
I downloaded the LP for my phone and the "contact" icon on the dock and I can't click it...Says could not launch! Anyone else have this issue?
yea, it come setup to work w/ a different apk.
just longpress on it and change the shortcut to the contacts app and it will work
Long press the icon on the Dock. Then select "Change Shortcut". Then select "Applications". Then select the contact(s) which ever it is...theres only one. After then select "default icon" viola!
