Leather options other than TETDED for S7 Edge?
BBIronMan
19
I'm looking for a snap-back case for the S7 Edge - just to help my fat fingers from always triggering screen functions. TETDED seems to be a popular choice but I've also seen a # of posts indicating they wear pretty poorly and quickly. Any other leather snap-back type options? The non-folder types. Thanks, Cheers.
EDIT: I should've clarified not the numerous poly/pleather/glued leather options. Otherwise there are a ton of options.
Leather is my option, although it looks a bit bulky, but I like the natural feeling. Hah...
Abheetha Athukorala
