LED indicator turns on when charging, but screen is black and won't connect to PC
  • Start date Start date
A
Android Central Question
I while ago I dropped my Samsung galaxy S6 on the ground. Although the screen is not cracked, it won't turn on. I have been trying with no success to get the phone to connect to a computer so that I can remove my pictures. When plugged in the computer doesn't even register that something is connected to it.
the Led indicator turns on when the phone is plugged in to an outlet so I know it at least responds a little bit but it still refuses to connect to the computer. I have tried it on multiple PCs with multiple cords with no luck.
I realise its probably hopeless but any help on how I could fix this problem and save even some of my data would be greatly appreciated. Thanks!
Welcome to Android Central! If you press and hold Power for 20 seconds, does anything happen at all? Does the phone make any sound or vibration? If not, then it could be a faulty Power button or more significant damage to the motherboard. You'd probably have to take it to a repair shop.
Whitehorssey
