LED light not working :(
melissamk1979
4
I just got my new Galaxy 3 today, insurance had to send me a new one because I shattered the screen on my one week old one. I finally got all my settings the way I want them and realized that the LED light is not working. I have notificiations LED lights set to on so I have no clue what is going on. I did some google help and tried the testing of the LED lights in the phone keyboard screen when you type *#0*# the led lights do not come on. Does anyone have any clue what could be wrong? I really want my LED lights to come on, but I do not want to have to return the phone and set up another.
Thank you for your help!
Check to see if quiet hours are on in your settings
There is a jelly Bean feature that can turn off the notification light and other setting during certain hours ago to find it, I believe you have to go through sound settings first
Sent from my SPH - L710 running Pac Man Rom, like a #Bawse
Yes, you are correct. I did do this through a warranty claim. Ohhhh what a bummer!!!! I finally got everything set up. I dont know if I really want to do that again :( I guess now I know I will check that setting before spending so much time getting it how I want it.
Do the led light up when charging? Might tell you if it don't work at all or maybe a setting issue.
Sent from my SCH-I535 using Android Central Forums
I know that feeling lol. Just do while your at work so you're getting paid and killing time ;)
Galaxy SIII - Thanks Appreciated!
My Podcast - http://cyberears.com/index.php/Show/audio/6030
My Blog - https://www.blogger.com/blogin.g?blogspotURL=http://bearpastarocketpop.blogspot.com/
I like the way you think, lol!!! It doesnt turn red when charging either. I was going to try and see if I really need it and live without it to avoid setting it up, but its not worth it. I think I will have to go ahead and bite the bullet and set up a 6th phone in 4 months! Hopefully this will be the end of it. Thanks guys!
My Podcast - Podcast Hosting | People Friendly
My Blog - Bear Pasta Rocket Pop
aimalee
