LED notification help
4424
Active member
Mar 20, 2011
26
9
Hi. Previous to this update to GB, I used an app called LightFlow to override the LED charging notification. Since the update, it does not work so whenever I charge my phone and get an email I have no idea unless I turn on the screen (mine does not blink). Any suggestions? Any other apps that work for this purpose?
Thanks in advance.
just one question do you have notifications turned on? because they can be turned on and off all together or you can select just what you want to be notified for.
Hixson21
