LED Notification Light
It does and no it's not very good at all.
Thanks for your feedback. Can you recommend any other models with similar specifications and a good notification light. I have a Samsung S5 at the moment and couldn't be happier with its LED.
Thought of that but prefer something that was launched with Android Pie given that most phones only get two OS upgrades.
Fair enough. Well the S10 variants are just around the corner if you have the patience to wait a couple of months.
Any clue as to whether the S10 lite/E variant will have a notification light ?
I'm not sure, with the bezel all but disappearing and there only being a hole I couldn't say for sure.
I have the Mate 20 pro and whilst the led light isn't the best it works for me. I can see it flashing away when there is a notification.
Do the mate 20 and the pro have the same size led light? Is there an easy way how I can invoke the light to switch on when testing out a phone in a shop?
The LED light is small but it's good enough, you won't miss it. Couldn't be happier with the Mate 20 Pro honestly by far the best phone out now.
NewGuyinKY
