LED notification
Takes some tweaking and experimenting, because it is loaded with options, but I've been using it for a long while over multiple phones.
I just messed with it a bit. A lot of options, using the free version for now to see how it goes.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
Good. Definitely look through all of the options and menus. I couldn't live without this app.
For some reason that light flow app doesn't work on my Note 3
Sent from my Note 3 on AT&T
Yeah, set it up for Gmail and SMS and some other apps but no luck. Tinkering with it some more.
I use NoLED instead of the notification light, works for me
Sent from my SM-N900P using AC Forums mobile app
Does anyone know what the default led uses are already.
Vector
