Let's see those camera pics!
First two are HDR Photos of thunderstorms over Oklahoma...
The second two are Auto settings Photos of thunderstorms over Oklahoma...
The last shot is a 4 shot Panorama Photo of thunderstorms over Oklahoma...
The camera on this phone is outstanding! Just could have used a wider angle lens to catch all mother nature had on display.
Wow. Number one and two are awesome. There are some shots that the HDR just does an amazing job with.
Sent from my HOX
Nice pics everyone. Unless I missed it, has anyone added pics from the front camera? Mine seems a bit LoFi if you ask me but it could be the conditions.
Sent from my HTC One X using Android Central Forums
Reactions: xXBLACKBERRYXx5
Don't know if its already been mentioned but when taking pics with default settings in full auto, the setting defaults to "Widescreen 16:9" mode with image resolutions of 3264 x 1840 which is really a 6 MP shot. If you change it in camera settings to "Widescreen 4:3" your image resolution then jumps to 3264 x 2448 which is your 8 MP shot.
Something to keep in mind.
Also, don't let it auto adjust your ISO speeds, its calculations are way off, putting normal lighted shots anywhere from 500-1000. Manually setting it to 100-200 for closeups, 200-400 for stills, and 800ish for action will net you much better results.
Auto white balance seems to be doing okay, but if your colors aren't coming out the way you intended, might look at manually setting that depending on your environment.
Those look great! Did you do any post processing?
Patio at 5mp
10+lb 28 inch bass caught last week
Awesome photos,I love that aquarium....I have fresh water myself.;)
sent from my Evo4LTE
Nice tank smith. Nice pics too. I just broke down a 300 gallon and moved to a 59 cube. the quality of all the photos everyone has taken is unreal.
This garden spider was taken with the close-up setting and a modified depth of field. I'm new to using the phone (hence it's only imag0031). Thus it took a while to find the depth of field setting so the orchid on which the web was spun was not the primary focus of the camera.
Took this with standard settings, I believe. No post-processing, other than cropping the left side to remove my finger from the image :S Haven't had much practice taking pictures with this phone yet, but it does a pretty good job.
Taken at the Pool at Sch?nbrunn Palace in Vienna, Austria:
attachment.php
noroldie
