Let's see those home screens!
Got some good battery life today. I charged it last nite and got home a little while ago. heres some screen shots...
Here's mine for now. I'd like to change the static app buttons at the bottom (phone, contacts, messaging, apps), how do you do that? Do I have to download a theme?
Open the app drawer, press menu, then edit, then find the icon you want in the dock and drag it there to replace one. Doing this changes the app sorting,to go back to alphabetical, just hit menu again and hit 'view type'.
Reactions: mnosaj and Phenom
click applications>menu>edit then just drag and drop apps to/from the app launcher.
Sent from my Sprint Epic 4G Touch
Reactions: sndplace
Here is what I have settled on so far....
Its G-Simi clock widget set right next to the BeWeather 4x2 widget. All set in ADW EX with a 5 slot dock and a few home screen shortcuts.
Cheers
Sent from my SPH-D710 using Tapatalk
How did you get that clock widget to be somewhat opaque and see through? i've been trying to adjust mine for a while now thanks.
Tap on the widget and go to Settings. Scroll down the setting to 'Background Color'. Adjust the Alpha lower to make the widget more translucent, make sure Red, Green and Blue are all set to zero. Tap 'Ok', then 'Save' and you're done!
Reactions: Longie11
Dumb question alert: Why are some of your home pages on page 3? And I notice on my phone, page 1 is blank. Why is that?
While on your home screen, hit the menu key and choose edit. You can now delete blank home screen "pages" my dragging them to the bottom of the screen. People who have screenshots on the 3rd page probably deleted a page or two.
And pages 1 and 7 are left blank so that you can add whatever you want to them. Or delete them.
I just learned about Go Launcher and am playing around with it. Also tried out the Live Wallpapers, which are awesome! Probably not good for battery life... but they look SO cool. :)
Ashok Dharshan
