Let's see your New Nexus 7 home screens.
Inspired by this
http://mycolorscreen.com/2013/06/09/gui-by-ah98/
Here's before I found custom launchers, I tried to keep as stock as possible. I LOVE stock android. :)
And after, my chrome os theme! Absolutely adore this theme and chrome os and now it all matches perfect. :P
Sent from my Nexus 7 using Tapatalk
Finished for Now at least! :)
Decided to streamline and clean up my screens a bit. Decided to go with an Assassin's Creed "theme" or rather motif.
Lockscreen
Main Screen. Photos at top change out at 5 minute intervals, whilst the lower photo is static
Don't mind my foot
Final Version...haven't changed it in a week ...guess I'm done until I get inspired by something else.
SSlauncher The Original
Aego Slideshow Widget for 2 top photos that change out at 5 min intervals / Bottom photo is static
Red Circle Icon uses popup widget for weather forcast
NewsQuical! widget for scrolling news
Bottom left icon uses popup widget for Folder Organizer for my most used apps
Various Zooper / UCCW widgets for time / battery status and date/calender
I received my Nexus 7 this week, my first tablet :D ..... I want to keep this as much as stock android as possibly, but there are a few widgets I'm seeing in these screenshots that I would like to have. Help is appreciated.
Apex Launcher
CM 10.2 kang with Slimbean gapps
Its a family tablet
What is the name of the widget that is displaying the time/battery/storage?
What calander widget is that? The second pic.
The first picture (not mine, but I can give you the answer anyhow) is the DashClock Widget. I use it on my Nexus 7's lock screen, but not for battery info. There are a whole bunch of extensions for DashClock to display all kinds of information (I use it for weather, and notifications on my lock screen) and it can be found on the Play Store right here: https://forums.androidcentral.com/e...et.nurik.roman.dashclock&hl=en&token=I5Kwa0uO
The calendar widget in my second screenshot is from Zooper Widgets Pro. The time/date/weather widget in the screenshot is also from Zooper. It can be found on the Play Store here: https://forums.androidcentral.com/e...ails?id=org.zooper.zwpro&hl=en&token=dwKfaQJV
The first picture (not mine, but I can give you the answer anyhow) is the DashClock Widget. I use it on my Nexus 7's lock screen, but not for battery info. There are a whole bunch of extensions for DashClock to display all kinds of information (I use it for weather, and notifications on my lock screen) and it can be found on the Play Store right here: https://forums.androidcentral.com/e...et.nurik.roman.dashclock&hl=en&token=eZBkK051
The calendar widget in my second screenshot is from Zooper Widgets Pro. The time/date/weather widget in the screenshot is also from Zooper. It can be found on the Play Store here: https://forums.androidcentral.com/e...ails?id=org.zooper.zwpro&hl=en&token=d6WAxZQ9
Thanks a lot! I appreciate your help!
Dashclock. There's a bunch of extensions for just about everything!
What icon pack are you using?
hincapie
