LG G Pad 8.3: Good case yet?
This actually looks really nice. Seems better than the options sold on amazon. I'm happy with my two case (from amazon). But I would definitely consider this if I wanted a case like that. Thanks for sharing.
Sent from my LG-V500 using Tapatalk
No prob 😉
Sent from my Galaxy Note 3 using Tapatalk
HI shastrich. I just read that the Verizon LTE version the camera, headphone jack and other mics/holes are not in the same place as the WiFi version. Would you confirm that all ports/holes are open and not partially blocked. Thanks!
Not sure he can. If you look at the photos, he has the Verizon version, thus for him all the cutouts will be aligned. We need someone with the WIFI version to pick this up.
I indeed have the Verizon version so I'm not sure if they are in the same location as the wifi. If you are looking at the tablet vertically- top left corner is your mic. Top center but slightly to the right is your micro sd card slot. Another hole to the right of that for the IR I think. 😞 Nothing on the entire left side of tablet. Right side of tablet- towards the top is the power button and right under that is the volume keys. Bottom of tablet- Charger port in the center. There's also a really small hole about an inch to the left of that but I don't know what that is. 😞 hope this helps!!
Sounds just like the wifi version.
Thx for the details. From what I read the Verizon LTE version ports are just slightly moved compared to the WiFi version. I guess I would have to visit a store to try out.
That'd be my recommendation. If it works, you'll DEF love this case!! 👍
Sent from my VK810 4G using Tapatalk
If you are looking for a sleeve instead of a case, I just ordered one off of Etsy that was customized to the dimensions of the G Pad. I will try to remember to give an update on here when it is delivered. You can ask for different colors, accents, and with or without a pocket or magnet. You can see different variations of the sleeve in their store.
https://www.etsy.com/listing/117721637/ipad-mini-retina-sleeve-pouch-case-cover?ref=related-0
I've bought a neoprene and a zipper case off eBay in the past few weeks that were described to fit, one is too small and the other too big. Would be interested to see how this fits.
Ok I'll be sure to update this. The designer who makes them ships from Latvia so it may be a couple weeks.
Sent from my VS980 4G using AC Forums mobile app
I just picked up the IVSO case for my Verizon LG G Pad, and while it is OK, I really miss the case on my Nexus 7. It is similar to the StilGut case that has been mentioned on this forum, but (very important), it has a strap that allows you to keep the back secure when holding it with one hand (in bed, for instance). Take a look at the pictures. Anybody know if a case like this exists???
Amazon.com: MoKo Slim-fit Case for Google Nexus 7 Android Tablet (Black): Computers & Accessories
Here you go, i also love that case, its $16 with free shipping from Aliexpress, ships from china but its the only way to get one unless you want to pay $45 on amazon for the same thing
http://www.aliexpress.com/snapshot/6064331353.html
Dugoh1
