lg g2 audio and display issue
arclite2012
Hello guys,
Since a week my g2 has been behaving strange.
The audio has completely stopped working be it from the loudspeakers or earpiece. Even the mic is not working. Although, when i connect the headset, the audio in the headphones and the mic of the headphones work. At this time i tried rerouting radio to loudspeakers and they didnt work.
Since this issue the display switches off when i make a call and doesn't come back on till the person on the opposite side cuts the call.
It has made my device completely useless. I tried flashing cm12 nightly and then flash a modem according to the instructions on http colon /forum dot xda-developers.com/lg-g dot m-fix-t2810492
This also failed to work and the same issue continued.
I was running stock 4.4.2 when this issue happened
What do you guys recommend
Thanks
welma969
