Lg g2 battery issues?
Ryan Atchason
Active member
Apr 23, 2013
30
I've had this lg g2 for about 1 month and I see everyone's battery life with it and mines pretty bad. I'll post screen shots but let me explain first I get about 4-5 hours of on screen time with location services off sync off Manual email refresh and Bluetooth off.
Welcome to Android Central :)
4-5 hours can be normal depending on your brightness settings, mobile data signal, etc.
You'll have yo use Tapatalk or the AC Forums app to post screenshots
Sent from my Galaxy S4 running SlimKat 4.4.2
Well I see the majority of people getting at least 6-7 hours. And if this has such great battery life then why did my iPhone 5 get better battery life it got like 6 hours of screen time
Higher screen brightness will use up more battery than using auto or a lower setting.
My sister has an iPhone 5. She gets nowhere near 6 hours of screen time...
How's your cell signal? If cell signal is poor in your area, that can contribute to battery drain, since the radio is straining to find a good signal. In the battery stats, tap on Cell Standby (if it's there) and see how much "Time Without Signal" is listed. If it's a big percentage, that might be your problem.
By the way, it is pretty easy (as mentioned above) for you to install the Android Central Forums app, login with the same Android Central credentials, and post a reply with an attached screenshot. It would help us try to figure out what might be contributing to your battery usage. Post the battery stats, the cell standby, and the screen-on time.
Let's get this discussion back on track before it goes somewhere we don't want it to go.
Sent from my Galaxy Note II
kiki2025
