LG G2 case
I took a chance on the otterbox commuter. Even though it says you can't use it for Verizon LG G2. It fits without a problem. The only thing I don't like about it is the plastic is roughed up but still a little slippery. For that reason I wish I would have gotten the Incipio dual pro.
Re: Lg g2 case
I have an Incipio Dual Pro case and the Zagg "case friendly" screen protector and they seem to play nicely together. I also have a Ditztronic case that also works well with the Zagg screen protector.
I do too. I have the Diztronic case too and I really like it , but never use it as I am so in love with my white/gray Incipio Dual Pro case. I have the Zagg screen protector too.
Re: Lg g2 case
My box said the same thing but inline said for. Verizon phones. It fits perfectly and makes the back button easier to use
I use Zagg's InvisibleShield High Definition Case Friendly protector (which should be compatible with almost any case), and an Otterbox Commuter series case. I've had no problems with peeling around the corners in the 3 months I've been using this combo.
bni46
