LG G2 extreme screen flickering,how can I fix it?
Doosh02
My LG G2 started flickering a little bit yesterday. This morning it got so bad that I could barely use the screen at all. I disable weather app like some suggested in other threads. My brightness is at 20%. I updated to 4.4.2 since nearly a year.
I had to factory reset at the beginning of this year because of the screen freezing and lagging, now this happens. I adore this phone except for these issues.
Can anyone help?
Re: LG G2 extreme screen flickering
It's common problem of LG G2.
It is not software problem so you cant fix it by yourself.
Specifically, EMI Filter failure cause such screen flickering.
Not a screen assmebly problem(replacing screen asembly will not work)
soldering EMI filter correctly or replace it will fix screen flickering.
It is located near micro usb port.
LG already know it and you can fix it at the LG service center.
Lots of G2 users are suffering with such problem. and they think it is flaws in design but LG deny it.
Hey Bro. I need to know where the emi filter is to change the whole part. Is in the same part of the audio jack and usb port? Thanks
nubiapk
