LG G3 Mobile Data = No Push Notifications
hi i m unable to turn off my mobile data on lg g3 f400l the data is continuously on and in the setting i m unable to toggle it to off state can you please help .
My issue is similar but what I found is its not handing off from wifi to data and data back to wifi. Hard reset, still nothing. Driving me insane when I go to take Snapchat or something fast and it won't let me until I toggle the data!:mad:
Re: LG G4 Auto sync email message. Update manually
Hi Everyone!
I found a fix to email notification will not update unless you do it manually.
Go to the following on your phone:
- Settings
-Backup & Reset
Then under PERSONAL DATA
- Select "Reset Settings"
This change will not t downloaded apps, personal data or security, language and account settings.
This will ONLY if any system settings were changed, reset settings can return the phone to tis original behavior.
****Hope this helps you out***
Xarpolis
