LG G4 battery case for extended life battery
ryanhark
Well I have been experiencing a faster drain on my battery(s) so I purchased a Hyperion 6000mah battery but it's larger and doesn't fit my protective otterbox. The back that came with the battery is cheap. I was wondering if there are any quality cases out the for this issue.
I will suggest you MJP, This MJP battery will give a MASSIVE boost to your phone's life. Makes the phone a lot more beefy and a bit more heavy, but if you are a heavy user it is way more than worth it to try. The case/battery is flatter than the standard back of the G4 which makes it sit steady on table tops which I liked.
The charging speed is about the same as the original battery but 2 X more because its 6000mAh. The charging temperature is around 23 degree C which is quite cool. I had even tested to see the battery will hold charges.I fully charged the battery and left it unused for 3 days. Then put it on G4 and its still at 100%.
ddog1355
