- May 3, 2016
- 1
- 0
- 0
LG G4: Problem with the "KnockOn(double tap to wake)" Function
Hi Everyone
I have a LG G4 mobile with Sr No : S/N :507KPHG695248.
Since today morning I face the problem with the "KnockOn" Function.
LG's smartphones have long featured the so-called KnockON function. It's what you would call a "double tap to wake" – when the phone's screen is off, you just tap on it twice, and the device wakes up. Alternatively, if the phone is on, you knock twice on an empty spot in the home screen and it will go to sleep.
But in my phone many a times "double tap to wake" is not responding. Even the power button does not respond simultaneously.
I try these two ways to awake my phone:
1) insert the charger pin & phone awakes immediately.
2) take out the battery & replace again & start the phone.
Kindly suggest a proper solution.
Hi Everyone
