LG G7 Thin Q battery drains too quickly
nitastuff
I had the battery replaced not even a year ago because it had been draining so rapidly. When they replaced the battery, I was told that there were some other diagnostic things they could do if the replacement didn't help. I did not do that because it sounded like it would be cheaper to get a new phone. Now it is back to the same old thing, not lasting more than maybe 4 or 5 hours without having to be charged. I took it to Verizon and they couldn't detect anything obvious that would have caused it to happen. I admit, I don't know much about what settings I should have turned on or off to help with this. Any suggestions?
Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which may show Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
mhamzahr
