LG Logo keeps flashing?
how long did you let the battery charge for? If its any less than 3 hrs you don't have a full charge no matter what charger you are using. If its charged try the following. Take the battery out (not plugged in) and then press and hold the power button (this will discharge any static charge). Put the battery back in give it another trying. Also try booting the phone with just the power connected.
i tried this and this doesnt work any other solutions please help im going delusional.
Same thing just happened to me. Bought two new batteries, New battery opened up my thrive nicely ut drained completely even in a turned off position. Tried chargeing with usb and laptop, still the same. I have one new battery left but don't want to put it in the phone till I know what's going on. LG Thrive, have not even activated the phone yet.
My phone was stuck in fastboot mode started now the battery is down i have try to charge it using my laptop and charger it keeps flashing light on the screen without charging...... can you please help me..... LG p505 thats the model of the phone
I have a metro pcs phone, the admire or something, and it was working just fine yesterday but this morning (mind you the phone was fully charged) it shut off and when I tried to turn it back on, the Samsung logo kept flashing. It would look like it was turning on, then shut off, and repeat. I tried charging it but that's not working. It does the same thing with the battery picture. It shows up, then disappears. Help? :c
please i need help. I do hard reset on my LG F100S but the media scan can"t work so i flash my LG F100S but my phone keeps on restart and can"t work. please help me out. i think my LG F100S is dead so help please.....
Strange but it works -- the original LG Thrive micro-USB cables work in the battery zero-power condition,
whereas other run-of-the-mill micro-USB cables do Not work.
Is this true with all LG cell phones ?
JeepsG Logo keeps flashing?
So my Phoenix died earlier today, and when I plugged it into a charger, it keeps flashing the LG logo and then repeating that, until I unplug it. I let it do that for a while just to charge, but the phone won't turn on at all now. Holding down the power button won't do anything. Taking the battery out and plugging the charger in causes the same thing to happen.
I'm running Jobans kernel 2.08, and CyanogenMmatt
EDIT: Its fixed now. Does anyone know if a different charger can cause something like that? Cause I was using a different one, but when I plugged in the original LG charger, it worked
Just remove the battery and charge the phone. If phone works/on properly, definitely the battery was dead. In that case, charge the phone without battery for a 10 mins and place the battery without unpinning the charger. It worked for my phone
Pickle240
