Lg Optimus V Infinite Clockworkmod boot cycle
Xionia worked, but i can't install any roms, well atleast not any non-stock roms. what happens is that the rom says it installs fine then when you go to reboot (this is with cyanogenmod) it gets to the swirl circle thing and wont get past that. any ideas.
Sounds like you didn't do a full wipe before flashing?
Tapatalk'n it from my VM670 running OM-Mandylion on LS670ZVJ firmware
Did you install the ZV9 twice as instructed.
If you did then you shouldn't be seeing Xionia.
If you used the root zip I linked you to you would have the BobZohme recovery installed?????
Please tell me in detail everything you did to install the ZV9 update. Start right after you got the Xionia recovery.zip flashed.
I installed Xionia and it went to the bootloader so from there i went to install my stock rom that i have, it booted just fine so i ddnt think anythin of it, then i decided i didnt want the stock rom and put a canogenmod 10 rom on and thats where i am.
cinemacritic
