LG P-350 (Optimus ME?) BRICKED help pls
vangoda
So i've got this phone for about 2 days now. Main problem was that I couldn't connect it to my pc via USB cable. Well since i had other ways to get stuff on sd card i didn't care too much about it. Issue at hand right now is that I used ROMmanager to get clockwork recovery and the phone is stuck at :
"Fastboot mode started"
"udc_start()"
When I connect it with USB cable it says --DISPENDED--.
I tried to use KDZ_FW_UPD software to restore my phone from emergency mode but it can't find my device over usb cable. I installed LG United Mobile Driver and disabled the modem thing but still no results. I tried this on 2 PCs and now im really worried that it's unrepairable.
I'm sorry for my grammar as English is not my main language.
If you need more info i'll try to give you as much as possible.
hmm. sounds like the device isn't showing itself to the PC. you are still under warranty. call company and ask for a replacement. or back to store for one. some apps on the play store just are not safe for use on all devices.
Vresbudsbenz
