LG V10 OEM Wireless Charging back cover on Best Buy...................
Refer to LG V10 user manual https://support.t-mobile.com/docs/DOC-24222, There is Qi wireless charging function was integrated with your V10. After review LG official wireless compatibility tab to see complete compatibility information, you need an extra LG wireless charging case to replace the original back case.
It works by using inductive charging technology to allow your V10 to charge without connecting a charger. No longer will you have to search for your charger and orient it the correct way just to plug in your phone
I seek V1O Qi wireless charging case and transmitter on amazon, wireless efficiency whole kit at $39 maybe workable, see http://www.amazon.com/Wireless-Char...ag=hawk-future-20&ascsubtag=UUacUvbUpU4881371 , or you can consult your carrier before purchasing, hope it helpful.
chzahid600
