LG V20 Tips & Tricks!
Expand your screen size by hiding the Home Touch Buttons!
This tip really makes the LG V20 look practically bezel less. Go to Settings, Display , Home and touch buttons, Hide home touch buttons and turn them all ON. This will remove the dock from the screen. When you want your dock (or Home and touch Buttons) to reappear just swipe up from the bottom of the screen.
The Home and Touch buttons will always stay on when in "settings"
Re: LG V20 Tips & Tricks!
I discovered LG's Smart settings with this device, I made a guide here that you can use to get them back if your carrier decided to hide them from you.
Did you know ir blaster can "learn" ir codes of obscure devices? I have a cheap remote control fan that I can now control with my V20.
QuickRemote App uses this capability. Many others only allow you to choose from a list. If device not there you're out of luck
More tips:
Double tap the notification bar to lock/turn off the screen at ANY app screen.
Also you could pinch to zoom in and out of LG default apps like messaging to increase or decrease font/icon size.
You can take a selfie with the gesture showing 5 fingers and then turning that hand into a fist to begin the 3 second countdown.
If you install the calculator apk from the older LG G4/V10, you can add it to the floating Q Slide apps. Q Slide is located in the home touch buttons options in settings.
More themes can be downloaded from the LG Smart World app or the Google Play Store. There are some free ones on there. I really like the Grace UX theme. G5 & G6 themes are all compatible.
You can add emojis to the second screen signature for more creative ideas.
SOME type of widgets can be added to the 2nd screen app shortcut.
You can download and use 360 photos as wallpaper. Pretty cool but will drain battery. You can also use the LG 360 cam and create your own 360 photo.
For faster low-light camera focus, change camera mode to manual, then change the S setting to 1/50 and adjust ISO accordingly. Nearly as fast as the S8.
Go to settings > mobile data > messages > then enable unrestricted data usage for automatic downloading of group SMS or MMS messages.
For optimal battery performance, try installing Greenify and Force Doze. Do not use auto app hibernation for Greenify and only manually hibernate apps once in a while. For Force Doze, you'll have to install a few apps on your PC and also the phone USB driver and then run some commands on ADB. I get between 4-6.5 hours SOT.
Slickwraps and D Brands offers great skin wrap protection and better grip for those who want to use no case OR change the look of your V20.
You probably already know this but you can press and hold the home button, then swipe up for Google Assistant.
Dual window. This is a feature on Android Nougat. While in an app screen, press and hold the recent apps button from the home touch buttons (square button). Now you can select a recent app to begin split screen, OR if you press the home button (circle button), you can go ahead and select the app you wish to split screen with. Great for listening to YouTube music while doing something else. *Note: not all apps may be compatible.
Nice trick.
Wish it worked with messaging and my Outlook server, as in both of those I keep hitting commands in that bar while typing.
Go to settings > general > about phone > software info > and then tap 'build number' 3 times to enable developer mode. Then go back to settings > general > developer mode > and then scroll down until you see "window animation scale, transition animation scale, and animator duration scale. Now turn them all off. Now watch how fast and fluid your OS will be! I do this for all my other android phones, a huge improvement in speed when navigating through the OS.
Then go to settings > networks > mobile data > and then go through your apps and pick the ones you DON'T want to have background data permissions (such as Facebook) and then press disable background data. It'll help you save battery and data. Alternatively you can enable "data saver mode" as well from the notification bar dropdown shortcut.
Last but not least, install the following free apps:
ForceDoze
Greenify
Follow the instructions from the ForceDoze app and enable it. It will significantly improve battery life when the phone is idle.
Install Greenify and tap the + symbol to select apps you want to hibernate. The developer suggests that you only hibernate apps YOU RARELY USE. Then occasionally, press the hibernate button and hibernate those apps. You'll see an improvement in battery life. On average I get around 5-6 hours SOT. Sometimes more, sometimes less (depending on usage and apps installed).
Thanks for the animation tip. It definitely seems faster.
hi i hope i'm not responding to a terribly old post. but i am only a week into V20 (from V10)...
should i follow the above instructions if i am using nova launcher?
thank you!
thank you!
Go into the Nova settings under look and feel.. Set all animations settings to faster than light.
Mac
thank you!
Yes. With Nova Launcher, you can edit the homescreen transitions to be faster. But outside of that (text messaging app, settings menu, etc. will open/load faster without the animation crap).
Not to mention, forcedoze doesn't even work for Android N.. I used to use greenify with all my phones since it released, but for my v20 it seems to drain it. :-/
Force Doze now compatible with Android N. Greenify suggests to disable auto hibernation and ONLY hibernate apps that you rarely use. Apps not hibernated will automatically start when there is a notification.
This is cool...did not know.
heritagevines34
