Life Changing Device?
Sappy? No way.....I totally agree. I was able, with instructions, to install S planner widget and that has made this device truly a companion.
Sent from my SCH-I605 using Android Central Forums
S planner? I can't seem to find that app.
Sent from my SCH-R950 using Tapatalk 2
Here is how you do it:
Mods Please move this accordingly if its not in the right place.
*****************Must have rooted phone for this to work******************
*****************Like any other Samsung TW widget, this does not work with after market launchers*************
This is the Calendar widget apk that includes all the same calendar widgets as seen on other versions of the GN2.
Ok , I seem have solved my issues with the full screen calendar widget I ported over from the Sprint GN2.
The APK is deodexed so I just had to rename the original .odex file to something else.
Instructions.
1. Download the SPlannerAppWidget.apk and copy to your phone.
2. Using root explorer, Mount the System - App folder as R/W
3. Rename the original SPlannerAppWidget.apk to be SPlannerAppWidget.bak
4. Rename the original SPlannerAppWidget.odex to be SPlannerAppWidget.oder
5. Copy the downloaded SPlannerAppWidget.apk to your System - App folder
6. Mount your app folder as R/O
7. Reboot you phone
**********This works fine on my rooted Verizon Galaxy Note II. I am Not responsible if you mess your phone up.
Thanks,
How were you able to install the S planner widget? I have the Verizon version and it did not come with it.
He just went through the process. All you need to do is read it.
Sorry I didn't read the post before the other post. I'm not rooted so it won't work for me. I was hoping it would be a application that I could just side load without root.
So this is the stock large calendar widget? That I have. Thought it was something different.
xinyingt2
