Little help how is everyones call quality?
trigun123478
430
35
When I am talking on the phone I can hear like idk how to explain it, like a kinda buzz from the speaker when talking on it. Like the speaker is up to loud but the actual voice doesn't sound that loud its just certain tones make it kinda vibrate the speaker. Does this make any sense to anyone? or Should I try to explain it better?
Am not sure exactly what u are trying to explain. Try lowering volume a little
sent from my Incredible using tapatalk
Like speaker is up to loud, so the speaker is vibrating and kinda ringing but the actual voice on the other end isn't that loud. Turning it down seems to not help.
Mine's fine. I'm not having that issue. I had bad sound on the Tbolt I returned, yet many people here reported flawless call quality. You can try returning it and hoping for a better unit.
I, personally, have had amazing call quality. Maybe this is just a speaker issue with you or the other person.
I had the same problem. I did a little research and ended up following the instructions pasted below. It helped, though still not perfect. The hissing/buzzing was driving me crazy enough that I was ready to return the phone, which I absolutely love otherwise.
I included the link to the actual post, but I don't know if I inserted it correctly. If the link doesn't work just search the Thunderbolt forum for "hissing during call."
I hope this helps.
Dial ##7764726. (Spells program) Go to "Nam cdma setting" Scroll down to "preferred voice service" (there's 3 entries) Change them all to evrc-b Hit menu and commit changes.
http://forum.androidcentral.com/htc-thunderbolt/74373-finally-got-rid-hissing-during-call.html
I hope this helps.
did that get rid of it for you?
It also could be a bad unit, I agree with some others, the call quality on this phone is amazing - people sound so clear...
I am not having any issues as far as speaker sound is concerned. Try as others have advised and just reduce the volume.
I had the same problem as the OP and the fix does seem to improve the quality a little, its not perfect but there still is some slight hissing at the lowest call volume. At higher call volume setting it is a lot more noticable.
oh and btw the password is 00000
jerrsun
trecth
