Lock screen help
Hvacmanjc
186
6
Hello all. I downloaded one if the custom lock screen lockers and now can't figure out how to apply it. Does anyone know how this us dine? Thanks in advance:eek:
Sent from my MB855 using Android Central Forums
please let us know which one you downloaded
Its one of the Go Locker lock screens
I think you need to download the Go launcher and hold down the home screen and a menu will pop up select the locker option, select the locker you want and apply. some of them are paid, other you need to download a whole bunch of apps before you have enough credit to use it, others are simply free. let me know if that helped or not
I figured it out. I had to go in to the Go Locker app and change it. Thanks for the help and quick response. :thumbup:
lilyo7788
