Lock screen help.
byeblackberry
324
29
I have my settings set to display the time and date on my lockscreen. Set time shows up just fine but the date is not there. Any ideas?
Sent from my bad @$$ GS4 using Android Central forums.
Maybe you changed the text color of the date to 'Transparent'?
I did not change any colors. Not sure if you can't even do that. Is the date showing up on your lock screen and are you with Sprint?
sakhe
